stupid brakes, 96 integra Q???
look what you did!
What is the deal w/ the brakes on this integra? Like I said its a 96 Ls and I searched this and other forums, and from what I understand to compress the rear caliber you have to take the rotor off, put the caliber bracket back on the hub, place caliber back onto the bracket, then (heres where I get confused) with a prybar or something rotate it clockwise. Only its not rotating nor is it compressing. WTF
Its Lightish Red
Re: stupid brakes, 96 integra Q???
tool
pliers
I also took the master cylinder cap off when i did this, no need to apply pressure it sorta screws its way back in
pliers
look what you did!
Ok I finaly got it, heres what happened just encase someone comes across the same prob. When I used a c-clamp to compress the piston I guess I must have put it into a bind so when I tried to turn it , it wouldn't budge. Solution: step on the brake pedal just a little to pop it out, then (because I didn't have a box tool) I took a pry-bar and clamped vice-grips to the handle (for leverage) then it came free and rotated right on in. Got it and got her on the road.
Thanks for the help , everyone who helped.
