sr20det starting help!
Old 10-03-2010, 08:25 AM
1Slow2Forty's Avatar
1Slow2Forty 1Slow2Forty 1Slow2Forty 1Slow2Forty 1Slow2Forty 1Slow2Forty 1Slow2Forty 1Slow2Forty 1Slow2Forty 1Slow2Forty 1Slow2Forty
Default sr20det starting help!
I just swapped my short block from my old sr motor because the old motor shot a rod. I just tried to start it the other day and all it does is crank. It cranks and occasionally you hear it almost start. It sputters and you can hear it coming throught to the exhaust. I dont know what's wrong with it. I'm getting spark, I did the test and it was a blue spark. Im getting fuel I checked the rail and injectors were spraying fine. When i tried to start it again there was a wierd honk noise coming from the starter area. Im not sure if the starters bad or if something else is wrong with it.
1Slow2Forty is offline
Old 10-03-2010, 08:28 AM
woot! :D
The Guy's Avatar
The Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these partsThe Guy is infamous around these parts
Default Re: sr20det starting help!
Hmmmm, timing or ECU?
The Guy is offline
Old 10-03-2010, 08:31 AM
goon squad
funder.bunder's Avatar
funder.bunder funder.bunder funder.bunder funder.bunder funder.bunder funder.bunder funder.bunder funder.bunder funder.bunder funder.bunder funder.bunder
get yourself a new starter and ignitor chip
funder.bunder is offline
Timing is set back to factory. Adjusting the cas did nothing.
Old 10-03-2010, 08:36 AM
woot! :D
The Guy's Avatar
Then do this.
The Guy is offline
Old 10-03-2010, 08:42 AM
Thats what ill probably plan on doing. how can i tell if the ignitor chip is bad?
Old 10-03-2010, 09:48 AM
goon squad
because your car wont start.
Old 10-03-2010, 10:35 AM
Yeah but im getting spark on all my cylinders.
Old 10-03-2010, 05:56 PM
Hijacker's Avatar
Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker
CAS is probably 180 degrees off. You'll get spark, and it will stutter during cranking. It'll also backfire through the intake.
If you want, I can come out and take a look at it. I got nothing big planned for the next few days.
Hijacker is offline
Ninja11
03-23-2008 01:38 PM
bluesr240
08-28-2007 10:18 AM
StuntinOutlaw
05-25-2006 04:33 PM
mys142lo
01-22-2003 08:50 AM
Quick Reply: sr20det starting help!
