sr20det issue need help ASAP!
Old 08-26-2009, 03:45 PM
foatz's Avatar
foatz foatz foatz foatz foatz foatz foatz foatz foatz foatz foatz
Default sr20det issue need help ASAP!
My sr is building boost, but will not blow off through the bov.
I have an hks that has been on the car for awhile now, and have never had any issues before. The car idles ok, revs, and builds boost, but then surges the compressor. I am pulling a good amount of vaccuum. I checked my ic piping and its tight. This car is my daily, so I need to figure this out. PLEASE HELP!
foatz is offline
Old 08-26-2009, 04:13 PM
hottscennessey's Avatar
hottscennessey has a spectacular aura abouthottscennessey has a spectacular aura abouthottscennessey has a spectacular aura about
Default Re: sr20det issue need help ASAP!
If the only issue with the car is not blowing off, it sounds like you may have a ruptured diaphram in your blow off valve. It's not likely though, because your idle would suffer from a ruptured diaphram, as it would cause a vac. leak.
hottscennessey is offline
Old 08-26-2009, 04:21 PM
Danny@respecgarage
RE-SPECGARAGE's Avatar
I had the same problem on an old hks ssqv. The diaphram was bad and not letting the bov open. buy a vaccum pump from advance and check to see if the bov opens or hold vac
RE-SPECGARAGE is offline
Old 08-26-2009, 04:38 PM
foatz's Avatar
What causes this to happen? I have the new style ssq. Is it rebuildable or am I fucked out of a 5 month old bov?
foatz is offline
Old 08-26-2009, 05:33 PM
Apparently they're available, because it looks like HKS has a part number for just the diaphragm.
Google found this with the part numbers: http://www.hksusa.com/content/pdf1583.pdf
I didn't look any further than that..
By the way, check to see that the whole unit isn't seized up, that's basically the only other thing that can really fail on a BOV other than the diaphragm. They're pretty simple devices without a lot of parts.
Old 08-26-2009, 06:08 PM
foatz's Avatar
Alright man, thanks
foatz is offline
Old 08-27-2009, 02:46 AM
foatz's Avatar
What exactly should I look for when I take it apart?
foatz is offline
Old 08-27-2009, 08:57 AM
protomor's Avatar
protomor is on a distinguished road
Torn stuff. The diaphragm is usually a rubbery mesh looking thing. Youre looking for tears in it.
protomor is offline
LSX240
08-25-2008 04:39 PM
dc18rb
Want to Buy / Trade ARCHIVE
04-09-2008 09:37 AM
DAinteg91
01-28-2008 01:07 PM
Quick Reply: sr20det issue need help ASAP!
