SR20DET Help Please
<3's Photography
SR20DET Help Please
Alright, I have a Black Top and i was abusing it today. It was hot and humid as hell but heres my problem. After driving about 30 miles i came to a stop and the engine started lagging pretty bad. Sometimes it would be ok then back to the bogging. I'm thinking this is a boost problem b/c of the heat outside. Can that make a significant difference? Im at stock bost and have mild bolt-ons. Thanks
Lost Cat Magnet
Re: SR20DET Help Please
hmmm, maybe heat soaking the intercooler. do you have the sidemount still?
might wanna check your timing too.
nannerpus, nannerpus
Originally Posted by BigHead Ted
turn up the boost it will all work out in the end. jk
sounds like timing or heat soak
btw Jerry, the head is still sitting in my garage
<3's Photography
yes i do have the SMIC. I kinda checked for leaks but not completely. I dont have a boost gauge yet. Whats the best way to check for leaks? Can someone explain the effects of heat soak? Does it make you sputter under WOT?
<3's Photography
timing is at the stock 16 degrees also. I didnt alter it after the engine started after the swap. Do i need to adjust it anymore?
Administrator
Oddly enough the FSM makes no mention of heat soak for the problem of the engine stalling when it is hot. I wouldn't think you'd run into heat soak problems at stock boost.
__________________
Got a 1995-1996 240SX? Want a new front bumper?
Check this out. Posting on drag first to try and avoid shipping it.
Administrator
it just ran like shit
Maybe hesitation would be a better choice than stalling, but it still doesn't have any mention of heat soak though. Oh well, if you're happy with it being heat soak then I'm happy
__________________
