SR20DE fuel pump problem HELP
CLOSE THREAD.
Re: SR20DE fuel pump problem HELP
sounds like its running backwards, take the fuel line off the injector rain and turn it onto the on position, does the car even try to fire up or is it a dry crank?
Originally Posted by vaiowarrior
(Post 3792310)
What do you main by dry crank? It is cranking weirdly, like a constant cranking noise, but it won't start. It doesn't sound like it would. |
dry crank - a constant turn over speed, no quick splutters like its trying to start running
usually theres a valve on the fuel rail on the engine that you can press with a small object like a small screwdriver to determine if theres any fuel pressure at all or you can remove the fuel line after the filter. did you replace the pump only inside the big plastic housing or did you replace the whole unit, including the float? |
(Post 3792352)
where are you located? if your in my area ill come take a look at it for you. is the car inside a garage?
(Post 3792382)
