Speedo problem.
Old 02-08-2007, 09:27 AM
Bro'd Out
Tito's Avatar
Default Speedo problem.
well the speedometer has been struggling and works every now and again but lately (say past month or so) it hasn't worked at all.
i'm curious if anyone has any idea what it could be. it seems to only work during temperate weather but not in the extremes (i.e. in the spring/fall it works well but not in the summer/winter)
anyone have any ideas? sensor or maybe wiring?
ps: only reason i'm fixing now is because i got a ticket for it last night so i guess it's time to fix this badboy so i know how fast i'm going.
pps: cruise control nor odometer work since i suppose it's all linked to the speed sensor?
Tito is offline
Old 02-08-2007, 09:32 AM
Double Agent HT
ILLEGAL's Avatar
Default Re: Speedo problem.
what car? Prob the VSS
ILLEGAL is offline
Old 02-08-2007, 09:33 AM
Bro'd Out
Tito's Avatar
oh 95 integra by the way
VSS? is that just the tranny speed sensor? that badboy goes for $173. just making sure that is what it is before i go throwing money at it.
Tito is offline
Old 02-08-2007, 09:41 AM
13.5:1 Poor Mans R
Kana's Avatar
Kana has disabled reputation
Im in the same boat but i already replaced the VSS.
Im guessing the cluster?
Kana is offline
The Pro to call.
HatefulMechanic's Avatar
how bout you have it diag'd correctly instead of throwing parts at it?
a dvom will let you know pretty quick if its bad or not. a scope would help a hell of a lot better though.
HatefulMechanic is offline
Old 02-08-2007, 09:44 AM
Bro'd Out
Tito's Avatar
yeah ok. well i'm gonna check things one at a time. places just don't do diagnostics anymore and the one my dad has is for obd2
and right now i'm at home in chesapeake and you're in southwest VA. so that leaves me at a disadvantage.
Tito is offline
Double Agent HT
ILLEGAL's Avatar
well I have a brand new vss from honda in the box if you need one in nova. (it was for a 00 civic si, you can check the model #'s at the dealer to see if it's the same. I'm sure it is. There was 2 for the si though.....
ILLEGAL is offline
Old 02-08-2007, 09:49 AM
Bro'd Out
Tito's Avatar
well i'm gonna go start checking the vss. i'll be back periodically.
Tito is offline
The Pro to call.
huh? diagnostics is part of repairing a vehicle, unless you go to one of them tune and lube places that only know how to change parts out.
wait...i see what you are saying now. people rather swap parts till they fix it instead of figure out the cause.
year, engine, trans and i will try to get you a wiring diagram so you can run it down. or give me a location and i will try to find an ASA or IATN shop near you that i would send someone to.
Old 02-08-2007, 09:53 AM
Double Agent HT
ILLEGAL's Avatar
there is a way to troubleshoot a vss, it's in his hanes manual. No need to pay somone else to do it for you.
ILLEGAL is offline
Quick Reply: Speedo problem.
