speed sensor bad? help
i have a 95 eg with a gsr swap and my speedometer on my cluster isnt working or moving at all. the gas and temp gauges work fine and so do all the lights. so my question is how do i know if its the speed sensor or the cluster?
Re: speed sensor bad? help
Most speed sensor provide an alternating (AC) signal. Throw a multimeter on your VSS and jack up your car and spin the front wheels, you should see varied voltages/frequencies at different speeds if your VSS is working.
