speed sensor.240sx sr20det
Blang Blang
ok so when i bought my swap and put it in the speed sensor in the tranny was bad. i heard from someone that a s13 single cam on will work with my engine(s13 sr20det blacktop).we tried one(not 100% it was a sohc) and it was reading waaaay off (like 20 when i was goin 5-10). but i was also told that i need and s14 sensor.can someone please help me out for sure on which one i need so i can go ahead and get the right one. thanks
Re: speed sensor.240sx sr20det
if i remember correctly it all depends on your ecu if you have an S13 SR ecu you need an S13 VSS . 13 and 14 sensor are interchangeble with any trans so if it still reads off its a matter of borrowing someone sensor(oddesey ) and seeing what happens lol
you suck, i know it
The speed sensor has nothing to do with the ECU. It has everything to do with what gauge cluster you are using. The circuit goes from the tranny, to the cluster, then to the ECU last. The ECU has no effect on the signal from the VSS.
MoltenMetalFuzion
