sometimes hard shift and noise when press in clutch
Old 12-18-2007, 09:36 PM
I <3 KARMA!
resideinVA's Avatar
resideinVA has disabled reputation
Default sometimes hard shift and noise when press in clutch
problem fixed.
thank you everyone for your input and advice
close thread
resideinVA is offline
Old 12-19-2007, 05:37 AM
QUICKVIII's Avatar
QUICKVIII has disabled reputation
Default Re: sometimes hard shift and noise when press in clutch
Being hard to put in gear is a sign the clutch is draging. If it drags, don't take your foot off the clutch. Shut the engine off, retry to put it back into gear. Is it still hard to put into gear? Also if you can find someone to help you. Try to recreate the problem in your driveway. When it happens, keep your foot on the clutch. Have a friend try to use a pry bar to help move the clurch release arm further. Than try to put it in gear again, did this help? Also jack up the car. ENGINE OFF!!!. Remove the dust shield. use two pry bars, one between the block and flywheel, and one between the block and crank pulley. Pry back and forth on the crank. We are checking that the crank can't be moved forward and backward in the block. Shout back at us with some answers.
QUICKVIII is offline
Old 12-19-2007, 05:51 AM
I <3 KARMA!
resideinVA's Avatar
thanks. ill try that hopefully sometime tonight and see what happens
Old 12-19-2007, 03:12 PM
I <3 KARMA!
resideinVA's Avatar
i greased the shift linkage the best i could and saw the boot on the part that goes to the tranny is torn and there is little gravel pieces in it.
i dont think those little pieces could cause it to not shift sometimes though
anyone have ANY ideas??
Old 12-19-2007, 06:18 PM
QUICKVIII's Avatar
Did you try any of my suggestions?
Old 12-19-2007, 06:41 PM
TurboPipingSystems
thermal's Avatar
check the tranny oil..... add as necesary....
thermal is offline
Old 12-19-2007, 06:52 PM
I <3 KARMA!
resideinVA's Avatar
i didnt have a chance to do anything with anyone else and i didnt do the turn off thing. its kind of hard to in busy traffic but i will def try it and see if it changes anything. what would be signs of the clutch dragging? what exactly does that mean?
Old 12-19-2007, 06:54 PM
I <3 KARMA!
resideinVA's Avatar
its hard as shit to check it. i cant find the bolt to pull to check the it. i think i can see it but its near impossible to get to it
Old 12-19-2007, 08:05 PM
your mom has a SRT
White Thunder's Avatar
White Thunder is an unknown quantity at this point
the noise could be alot of things......my guess would be TOB....
i have a question for you though what are you mods on your teg.....is there really a reason for a stage 2 clutch on a car that has a hard time breaking 150 ft lbs.....that just puts extra stress on your trans/axels/and that beautiful lsd
White Thunder is offline
Old 12-19-2007, 08:18 PM
I <3 KARMA!
resideinVA's Avatar
yeah thats what i was thinking. that or the cable just not releasing the clutch completely. i dont have much time to look into things so i just want a more def answer before i go in and do all that to get the tranny off to look inside. all possibly for nothing
i just bought the car. all i know of as far as mods is the usual intake and somewhat custom exhaust and the B16 tranny with the lsd and clutch. it may have some internal mods but im not sure of it. i dont know for sure if it has a stage 2 but it doesnt feel much like a stage 2 clutch.
ive driven others with a stage 2 clutch and it was MUCH MUCH more sensitive. and thats why im starting to think its something to do with the cable. maybe its not tight enough to fully disengage the clutch. it eventually gets stiff at the very end of the pedal travel. but the first 3/4 of the way is effortless
Quick Reply: sometimes hard shift and noise when press in clutch
