someone help my car
Old 06-08-2004, 05:55 AM
1st timmer
todb84's Avatar
todb84 is an unknown quantity at this point
Default someone help my car
it's been happening for a long time. i start it up-it takes more time to start up like 3 or 4 sec more and sometimes it acts like it doesn't want to start at all. i think it's a sensor. the code says it's a crank angle sensor and i checked the book and it said replace the distibutor well i didn't think anything of it cause i'm lazy so....it eventually needed a new distributor so i put one on it and the dang thing still had the same problem(crank angle sensor). it will 1. stall out when the engine is cold and i come to a stop, 2. run low idle constantly, 3. not start up when engine is warm, 4. doesn't run past 4,000 rpm's, 5. check engine light comes on strong in first second and third gear but once the light comes on it idles a little better but still seems like it wants to stall but won't but check engine light won't come on until i've driven it for a while. dang sensor or something someone please help me i'm dyin to know what it is cause my friend has the same problem. HELP!!!
todb84 is offline
Old 06-08-2004, 05:57 AM
1st timmer
todb84's Avatar
Default Re: someone help my car
ps-it's a 90 accord sohc
todb84 is offline
Old 06-08-2004, 06:00 AM
corona connessuer
CHAHONDA's Avatar
what codes is the ecu setting?
CHAHONDA is offline
Old 06-09-2004, 05:38 AM
1st timmer
todb84's Avatar
help the code is 4 the crank angle sensor what do i do?
todb84 is offline
Old 06-09-2004, 06:45 AM
DESTROYS DONUTS !!
MORE IMPATIENT's Avatar
try replacing your crank angle sensor, and double check your timing.......
MORE IMPATIENT is offline
Old 06-09-2004, 07:04 AM
i got 5 on it
themacuser.org's Avatar
themacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these parts
I'm no ASE certified Honda Technician, but you MIGHT want to check out the crank angle sensor. Maybe.. just a shot in the dark, really.
themacuser.org is offline
Old 06-09-2004, 09:08 AM
1st timmer
todb84's Avatar
i have no idea what to check for.
todb84 is offline
Old 06-09-2004, 10:03 AM
hybrid no more :(
Bert's Avatar
i don't have the wiring diagram but that is what you'll need. you'll need to find out which pins at the distributor are the crank angle sensor as well as the pin outs for the crank angle sensor at the ECU. check the resistance between the pinouts at the distributor. the pinouts should read a resistance between 200-600 ohms(not sure exactly but that is a ballpark). if this is good then check connectivity between on pin on the engine harness at the distributor of the crank angle with the corresponding pinout at the ECU. you should have solid connectivity. check both pins. if this checks out then try another distributor and/or ECU. HTH
Bert is offline
Old 06-09-2004, 11:24 AM
1st timmer
todb84's Avatar
Thanks
todb84 is offline
Fl1pSde 101
Other ARCHIVE
32
06-18-2008 07:21 AM
04DaytonaZ
05-19-2008 08:26 AM
ShishCoBob
04-03-2006 05:44 PM
ShishCoBob
03-31-2006 04:49 AM
Quick Reply: someone help my car
