sohc problems
8===========D--
sohc problems
i got a d16a6 and it has a dpfi fuel injection(2 injectors) in it. last owner swapped it in.
car starts up fine but when you start stepping on the gas it will slowing go (bogs and it wants to go but wont go) until you hit 2500 then the car will start moving and drives normal
also when you launch the car at any rpm. it will catch traction just a slight second and then car starts idling down (rpm gauge goes down back to 1k) and wont want to go but goes slowly moves.
8===========D--
8===========D--
corona connessuer
Re: sohc problems
my thoughts exactly. i have put d16y7 in an 89 civic and it ran great. as long as everything is hooked up correctly it would run fine. was the timing belt removed/replaced/adjusted in this motor at all?
