skunk2 throttle body help!!!
installed skunk2 throttle body and now my car wont idle right and it seems like its dumping fuel? how does this happen off a throttle body install? any help is greatly appreciated.
Re: skunk2 throttle body help!!!
no stick. how do i check the tps ? if i loosen the tps and move it back and forth it really doesnt get any better or worse. if you give it a little gas it still studders until like 2k rpms or so. i really just dont understand this
use a multimeter and go off the red wire on the tps with the positive on the multimeter and the neg side of the multimeter on a body ground and turn the tps till the multimeter is at .45 volts that shuld fix ur problem......pm me if u need more details
