skunk2 mani on gsr = check engine light
Old 06-25-2012, 09:47 AM
kadafiz's Avatar
kadafiz has disabled reputation
Default skunk2 mani on gsr = check engine light
b16EFsedan WINS ! "did you possibly swap the iacv and tps sensor plugs? its actually a common mistake"
thanks all
kadafiz is offline
Old 06-25-2012, 11:32 AM
Unregistered Member
Travis.'s Avatar
Travis. Travis. Travis. Travis. Travis. Travis. Travis. Travis. Travis. Travis. Travis.
Default Re: skunk2 mani on gsr = check engine light
Why don't you check the code yourself, then you'll know the issue, then you'll know what to fix.
Travis. is offline
Old 06-25-2012, 11:41 AM
peaches
b16EFsedan's Avatar
b16EFsedan is offline
Old 06-25-2012, 12:42 PM
i pooped a squirrel
Gen_Crunchytoes's Avatar
Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes
Its possibly throwing a code for iab, matter of fact im almost certain it is.
Gen_Crunchytoes is offline
Old 06-25-2012, 03:12 PM
It's a P28, so unless it's running a P72 program without the IAB output disabled then there is no way it could be an IAB code.
Old 06-25-2012, 03:29 PM
i pooped a squirrel
true. but since he was tuned using a stock gsr intake manifold perhaps IAB output wasnt disabled then
Old 06-26-2012, 05:03 AM
kadafiz's Avatar
IAB is for certain disabled.. thanks though.. I might just check the god damn codes tonight!!!
kadafiz is offline
kadafiz's Avatar
Very possible ill check that.. I felt like the harness is pretty much dummy proof but I guess not
kadafiz is offline
Old 06-26-2012, 08:01 AM
i pooped a squirrel
Those two plugs are the same.
Anytime im working on someone elses car i always somehow get them mixed up lol
Old 06-26-2012, 09:00 AM
That's a horrible shortcoming on Honda's part. The first rule of designing something like that is to idiot-proof it so the plugs can't be mixed up. It doesn't matter if it's mechanically keyed or just color keyed/matched, something should have been done.
Quick Reply: skunk2 mani on gsr = check engine light
