-   -   signal light problem (https://www.vadriven.com/forums/tech-talk-9/signal-light-problem-230960/)
boostedteg Mar 27, 2008 06:01 PM
ok, i was driving down the road, hit my left turn signal to get over, looked at the gauge cluster, and the left turn light was stuck on, ive checked everything i know(bulbs, connectors, changed the switch, checked fuses, etc...) its only when the parking lights are on though, if the switch is off there are no lights on, you turn the switch on, both front and rear signal lights stay on, right side works fine, just looking for some ideas before i dig into a lot of wiring, let me know you ideas, im just confused because i didnt nothing more than turn on the signal, thanks in advance
boostedteg Mar 27, 2008 06:20 PM
Re: signal light problem
oh, and also, when the parking lights are off and i hit the left turn signal, all the lights(taillights,signal lights, and license plate lights) blink
BillMW Mar 28, 2008 08:08 AM
Relay switch in the fusebox? I had a 79 Buick that had directionals stay on....it's a box relay in the fusebox that creates the flasher. I know you said you checked that, but it's got to be something in there. The amperage drain on the relay from the parking lights operating could be causing this. Try replacing the relay and see if that works. Check your owner's manual. Usually what's what in the fusebox is undeneath the fusebox cover. Hope this helps. Good luck.
boostedteg Mar 28, 2008 12:23 PM
yeah man, ill check it again, but that wouldnt explain why when you turn the headlights are on, the left turn signals front and rear would stay on would it?
BillMW Mar 28, 2008 04:07 PM
Well if replacing the relay doesn't work I'd start looking for a bad ground. That would suck if that was the case. Any electronic gurus out there? I'm out of my league here.
p-stone Mar 28, 2008 04:28 PM
What make/model/year?
boostedteg Mar 28, 2008 06:31 PM
2000 honda civic
boostedteg Mar 28, 2008 06:32 PM
so far we have traced it down to the fuse box, checking that tomorrow
Fabrik8 Mar 28, 2008 09:53 PM
Could be a bad switch on the stalk, its rare but it shouldn't be a problem if your car is a 2000 model. There shouldn't be any way that the switch should be worn out already.
boostedteg Mar 29, 2008 04:01 AM
are you referring to the signal switch on the steering colom
