s300 base map help
s300 base map help
I just finished my build and pressure tested my cooling system for leaks before I take it to the dyno. Now I want to start it up check oil pressure, oil leaks and make sure there no over heating problems. My problem is the s300 has no base maps that will support my 1000cc injectors. If I put stock injectors in it I will have to do alot of rewiring because I wired a resistor box in my harness so I could use the 1000 injectors to start with. If I load one of the base maps that use the 550cc 16 ohms injectors it should work fine once I change the settings from 550cc to 1000cc. I dont know where to start, Can anyone give me a step by stem procedure on how to make those changes. Like I said I just want to run it long enough to get up to operating temperature then its going to the dyno if I don't have any issues.
tegstyles
Engine / Exhaust / Drivetrain
05-19-2009 01:59 PM
