S14 VTC wirring on an S13??????RS200 Oil cooler lines?????
Formerly Shinobi....
Can I make an S13 motor run off of an S14a VTC ECU? I was wondering cause i think the S13 can be wired for VTC and the extra 40 or so HP it respectably gains.....Not too sure if its possible but if so lemme know.........I also need to know how to install the Oil cooler lines to the Diff cover........Im completely lost there........(RS200 LSD)Do i have to have a t spliter for the oil lines or what? I dodnt even know where to start with getting the lines or where i can get them custom made for my application..........Please help.......
I dont know if you can make it run off the ecu, but you will not be able to use the VTC portion. the S13 does not include the mechanicals to allow it. Nor can it be added under any comon sense circumstances.
sounds like you have a bare S13sr and a full S14sr wiring setup. true?
Only reason I ask is my boy just recently upgraded to an S15 in his S14 240sx and he sold the motor but the guy who bought it didnt want the ECU or harness.........Just figured if it was all wirring then id Buy a solenoid and try it but if not oh well........(Wish i could have afforded the S14 SR...lol)
btw its only a 15hp gain and imo it aint worth it.....turbo your KA if you want low end torque that the VTC gives you.
the diff cover i think is only just a cover with plumbing in it to an external resevoir. a waste of time unless this will be a 24hour endurance car. i've had my white 240 on several road courses with plenty of power and never had a rear end problem. sure you can do it.....but why? i've found out that just because it sounds good on paper doesnt mean it will actually work on the car. (maybe this is why my cars are so lightly modified)
if you dont want that S13 sr anymore i'll take it off your hands if i ever blow this one up.
yes turbo the ka. one example was my setup that went 11.39@119, a KA with the exact same build specs and hp level and boost level, and cost of buildup the same
the KA ROMPED my ass on the dyno, nearly 70ft/lbs more torque 2,000rpm earlier and hp level earlier in the band. from the owner of an SR, keep the KA
PS. Im not sure cause i dont know too much about the KA24DE but could you mate an SR20 head to a KA block? If so has anyone frankenstiened like that before? Just out of curiosity.....
Or maybe swap internals such as rods and crank from SR to compensate for higher revs but still retain KA torq? like I said im not claiming its possible just wondering.......
nope, cant do a SR head on a KA head. chain geometry and design and bore size and bore spacing, oil feeds and drain feeds are all different locations. Actually, i think the KA head flows better than the SR head. also in theory on paper the KA head can rev higher given a bottom end that could as well. Think about this.....the SR is the only 4 cyl motor in the last 15 years i'm aware of that has 1lobe per 2 intake valves. And uses rocker arms. The RB series uses direct acting valve geometry, the ka does as well......but i love the SR for its easy of install and use and sheer stock powerholding ability. A buddy in FL has tested his stock block to 457rwhp uncorrected, 440 corrected RWHP. so many strong points and weak points of each motor......but i'll stop here.
i know a little about the VG30ET. got any specific questions?
