s14 sr20det help
Old 04-28-2006, 05:20 PM
gotta go gotta go
cr1m3rat3z's Avatar
cr1m3rat3z has a reputation beyond reputecr1m3rat3z has a reputation beyond reputecr1m3rat3z has a reputation beyond reputecr1m3rat3z has a reputation beyond reputecr1m3rat3z has a reputation beyond reputecr1m3rat3z has a reputation beyond reputecr1m3rat3z has a reputation beyond reputecr1m3rat3z has a reputation beyond reputecr1m3rat3z has a reputation beyond repute
Default s14 sr20det help
I need pix of anybody's iacv/tps sensors so that i can figure out if the one i have on here is right. Only for s14 sr20det. I thought that the iacv was suppose to have an air outlet but mine doesn't have one. cant get the car to keep it's idle when i hit the gas - it just dies. helppppppp
oh and pix of how the vacuum lines that lead in/ out of the throttle body should go would also be appreciated
cr1m3rat3z is offline
Old 04-28-2006, 05:27 PM
<3's Photography
240dreams's Avatar
240dreams has disabled reputation
Default Re: s14 sr20det help
Go to www.zeroyon.com and dl the S14 SR FSM. All of your questions should ne answered there. The IACV has an air outlet into the manifold where it's mounted. The inlet should be somewhere leading to the front of the motor. If it dies when giving it gas it's probably something else. IACV is mainly for idling with the throttle body closed.
240dreams is offline
Old 04-29-2006, 02:02 PM
gotta go gotta go
cr1m3rat3z's Avatar
already have that but the vacuum line diagram is different because the intake manifold inlets are in different places
Old 04-29-2006, 02:44 PM
<3's Photography
240dreams's Avatar
What parts are you trying to connect to the intake manifold? BOV, WG, FPR ?
Old 04-30-2006, 08:24 AM
gotta go gotta go
cr1m3rat3z's Avatar
yeah bov, waste gate etc
quick question if bov is fucked up will that cause the car to cut off? i was thinking that it couldn't
Old 04-30-2006, 08:27 AM
<3's Photography
240dreams's Avatar
If the BOV is open and leaking badly during idle, yes. You'd run rich.
Old 04-30-2006, 08:40 AM
gotta go gotta go
cr1m3rat3z's Avatar
hmmm.... gonna check that out now thanx
Old 04-30-2006, 11:39 AM
gotta go gotta go
cr1m3rat3z's Avatar
pix of throttle/intake lines
http://www.mytempdir.com/633587
really can't figure this out
Old 04-30-2006, 12:45 PM
<3's Photography
240dreams's Avatar
An S13 SR has similar outlets. Do you have your BOV connected to anyone of these? How about your wastegate? Try using those for either one. If there are any unused vacuum ports, plug them (they are probably from emissions control devices).
92sihatch
01-08-2009 06:18 AM
92sihatch
01-07-2009 07:27 PM
nis240drft
01-01-2009 12:40 PM
StuntinOutlaw
07-21-2006 08:14 PM
Quick Reply: s14 sr20det help
