s14 auto to 5 speed swap
Old 04-28-2011, 06:07 PM
pickupguy89's Avatar
pickupguy89 has disabled reputation
Default s14 auto to 5 speed swap
Ok so this is my first time doing this, im about to pick up a s14 and hes got some of the stuff to do it but still needs some stuff to finish it. this is what it comes with.
1) Comes with clutch pedal/master cylinder already installed.
2) Manual 5-speed trans with shifter/clutch fork included. (used)
3) Clutch disc + pressure plate + all necessary bolts included. (used)
4) Drive shaft included. (used)
What all will i need to finish it and how much is it?
where should i get these parts from...etc
thanks would like to know this ASAP
pickupguy89 is offline
Old 04-28-2011, 06:12 PM
Danny@respecgarage
RE-SPECGARAGE's Avatar
Default Re: s14 auto to 5 speed swap
Doesnt look like you need anything else
RE-SPECGARAGE is offline
Old 04-28-2011, 06:15 PM
he told me i would need, trans plate/gasket
clutch lines
slave cylinder
speed sensor
clutch kit (since his is used)
and what about lower shift boot, boot ring, shift dust cover?
Old 04-28-2011, 06:28 PM
Danny@respecgarage
Why are you asking if you know what you need?
Thats all minor stuff you can pick up at advanced auto. The speed sensor is the same auto/5speed.
Old 04-28-2011, 07:10 PM
Boost LeRoy
blksylv's Avatar
blksylv blksylv blksylv blksylv blksylv blksylv blksylv blksylv blksylv blksylv blksylv
i thought the auto speed sensor was bigger than the manual one and wouldnt fit iirc?
blksylv is offline
Old 04-28-2011, 07:13 PM
yaaat.
ryanherington's Avatar
do you have to run a 5 speed ecu on 240s?
ryanherington is offline
Old 04-28-2011, 08:35 PM
Boost LeRoy
blksylv's Avatar
as far as s14 if you run an auto ecu on a manual car itll throw codes for the missing auto components iirc
blksylv is offline
Old 04-28-2011, 09:01 PM
and im just making sure im not missing anything.
Old 04-28-2011, 10:38 PM
Boost LeRoy
blksylv's Avatar
http://www.ka24development.com/transmission_swap.html
this site is a good source for any other info that you should need concerning the swap
blksylv is offline
npicolo2
07-09-2010 07:19 AM
HORNY4ZORNY
03-03-2005 07:20 AM
Quick Reply: s14 auto to 5 speed swap
