Running lights not working on 96 civic
Old 03-08-2011, 06:31 AM
BlackHatch89's Avatar
BlackHatch89 BlackHatch89 BlackHatch89 BlackHatch89 BlackHatch89 BlackHatch89 BlackHatch89 BlackHatch89 BlackHatch89 BlackHatch89 BlackHatch89
Default Running lights not working on 96 civic
My rear running lights stopped working today my brake lights still work when I press the pedal. I replaced all four bulbs in the rear and checked fuses but still no luck can anyone help out
Thanks
Cj
BlackHatch89 is offline
Old 03-08-2011, 02:10 PM
Default Re: Running lights not working on 96 civic
Grab a multimeter, find out what circuit they're on, and check to see if the fuse is getting power. Replacing the fuse won't help you if that circuit isn't getting power.
Old 03-08-2011, 05:01 PM
last breath first
gdupfromfeetup's Avatar
gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup
ive had this happen to me. I had a set of jdm foglights all ran on the same circuit as my running lights and they wouldnt engage buy the brakes would. sounds like the same exact problem. Even tho the fuses arent blown, check to make sure there isnt any exposed wires touching. It's most definitly a wiring problem, we just had to rewire my foglights seperately and they worked fine. check fuse 27 under the dash.
gdupfromfeetup is offline
Old 03-10-2011, 09:18 PM
Close fixed thanks
onedayb20vtec
03-01-2010 05:00 PM
1 pito
06-15-2008 03:57 AM
aznboy
05-04-2008 03:03 PM
fili_pinoy
01-15-2007 05:25 AM
Quick Reply: Running lights not working on 96 civic
