rsx wont hold idle!!!! plz help :(
#21
Re: rsx wont hold idle!!!! plz help :(
the best way to get my car to crank up is to hold the trottle down and turn it over. any other way will flood out the engine. if i need to restart quick i have to unplug injectors turn car over(car runs for about a second) plug injectors back in and hope she starts up. she sometimes holds an idle but its extreamly rough at about 600 rpm anything under that it stalls,
#22
Anal hammer
That sounds much more like the ecu problem I had. Do what dude said, borrow a good ecu and see how it responds.
#23
#24
#25
after warmup.
#27
okay i will be resolving some of the issues it could be, today. i will post report later this afternoon.
#28
here are a couple pictures ive snapped wile removing my valve cover. it seems my timing is correct? and my cams look very nice and shiny, couldn't find a scratch on them. i haven't adjusted valves yet as i have not found a good k20a2 valve adjustment tut. im hearing 100k is the recommended time you readjust your valves in an k20a2 i have 115k i really hope this solves the problem. if not my next purchase is a new ecu or hopefully kpro
#29
100k is indeed Honda's recommendation for adjusting the valves. Unfortunately for the K series they do get a bit more loose before that interval. I'd adjust them and see what happens before blowing anymore money. Borrow a known good ecu if possible.
#30
so i checked my valves and some were a little tight and some were a little loose, nothing to major it seemed but im going to set them to a pec i found at a forum that a couple people could notice better responses in the motor so ill do that tomorrow and update ya! and good idea sinner, im having a friend come by tomorrow to swap our ecu out and see what happenes. still haven't checked voltage to my coils but ill asses that also tomorrow.
