Rebuilt b18b1 in 91 da integra problems! look look help help!
soo i have a 91 integra.. it had the b18a1 in to.. it was blown up.. so i found me a b18b1 and rebuilt it all but pistons and rods and put the stock b18a1 head on it.. i put everything back in my car and ive noticed a couple sensors are different(can u plz tell me what these connectors go to in the pic below)..soo i went to start the car and it will start up and run for a few seconds and then it cuts right back off.. then it takes spells and it will just turn over and turn over and turn over and just hit every now and then and act like it wants to crank but it wont.. and like i said when it does start it sounds great and sounds like it will run fine but it just dies right out =(.. plzzz can anyone help me out? am i missing any sensors? or vaccum leak? or fuel problem? or what? plz plz..
what do these plugs go to?
what does this plug go to?
MARK IT ZERO
Re: Rebuilt b18b1 in 91 da integra problems! look look help help!
as for the other wires... i suggest you get a wiring diagram and start tracing. have fun
where is the knock sensor located? on the b1 block? and btw... my car isnt 0bd1... its obd0? does that still mean its on the firewall>?
Build..Race..Win..
hey just to let you know I had a 90 integra with b16a, so the one you are holding is for the map sensor. 90-91 tegs have there map sensor mounted on the firewall instead of the throttle body. There is a bracket that hold the map sensor in place with 1 screw, then there is a hoses that runs from map sensor to the top of the throttle body right next to the idle adjustment screw.
As for the green plug not really sure but it looks like it could either go to evap purge solenoid valve.
The black plug looks like it would go to the oil sending unit, but you already have it plug up, so check to make sure your oil light is going off.
hope this helps
James
Just notice the black plug is not for oil sending unit.
hope this helps
James
