rear disc brake conversion??
JDM Monkey Tuning
im about to swap out my drums for discs on a 95 civic dx and i was wondering what all i need? i have the discs and control arms and the brake lines from the discs to the part that they unbolt do i need to get a new brake master cyling or prop valve? or the brake lines?
Boosted F2B
fabricating is fun
Re: rear disc brake conversion??
only thing that i saw that is different from your setup is the prop. valve. they are different from your model. you need to find one from a car that has rear disc. you need to find one that had 40/40 stamped on it. dont woring about swapping out the master cylinder. E brake cables can come from a lot of cars with disc also. like all integs from 91 and up. they are a little longer but you can swap sides that runs up to the lever so you can take up some slack on the them. if you need pictures just look on hondatuningmagazine.com and look through their tech page and look for there upgrade brakes.
