Radiator fan problems 98 gt
Well i was in a parking lot and then i popped my hood , and i noticed at that instant i could see my radiator fan moving mad slow. Then slower and then off. I drove home in a panic because I have had a 95 stang overheat for this same reason.
The car was in a wreck so the last owner tells me, and he rebuilt alot of things in it to fix it. Maybe he did somethign wrong? I just bought the car of him like 4 days ago and I am finding alot of hidden problems I was not told about.
Do i need a new fan? MY check engine light is already on for an 02 sensor and something esle, so atm i wouldn't know if this fan would make the check engine light go on.
Thx
Thx
Re: Radiator fan problems 98 gt
No, a fan won't trigger a check engine light, there usually isn't any sense input to the ECU even if the ECU controls the fan (based on coolant temp). Check out the fan wiring before you assume that the fan itself is bad. It could be something as simple as a power or ground problem, connector corrosion, or a bad fan relay (relays can fail once they get hot, etc).
You should check the voltage at the fan connection with the fan on and with the fan off.
Oh, also check that the fan can spin freely, meaning that there isn't anything blocking the fan from turning by itself. If it's been wrecked, who knows what's bent or twisted in that area..
Would u suggest these? I will make sure to see if it spins tomorrow.
baller/dickbutt#69
get it fixed correctly...no presidential solutions man....
It's easy to check where you have power (or don't), and if you have some voltage drop problem caused by a bad ground or corrosion. Whatever problem you have it should be fairly easy to spot based on the very visible symptoms you described.
put that bitch on a toggle switch. if that doesn help, buy a either a new motor for the fan or, a junk yard fan will work.
