Problem with LS-Vtec Integra
Trouble shooting:
My friend just got a LS Vtec integra. He was making a corner and the car shut down for some reason. It started back up fine. Then he went to full up on gas. When he was leaving the gas station the car just cut out completly and now it won't start. Any honda techs out there with any ideas? My friend really needs this car running quickly.
Thanx in advance.
Ask any questions that you guys need to get an idea I will ask him.
Thanx in advance.
Sumospeed #O.G.
Re: Problem with LS-Vtec Integra
If the car will not run, and you can not see any physical damage to something, the always check fuel and spark firt. Very basic. If you have fuel and spark, Then check timing. If all is good, car should run.
Sounds just like a dizzy problem, pull out the cables and attatch a sparkplug to them and see if ur getting spark. Spark is the only thing that usually stops an engine running like that. Fuel is usually always there, sometimes lacking or getting too much. Hope this helps, let us know what the outcome of this matter is.
Originally Posted by BMC
SHITS GONNA BLOW UP *****!!!
turbo on 2 wheels
my boys car did the same thing the other day, and come to find out it was just a ground on the thermostat came loose, check your grounds too!!!
