Possible engine swap for 92 civic?
Old 08-11-2011, 10:52 PM
GreaseMunky's Avatar
GreaseMunky has disabled reputation
Default Possible engine swap for 92 civic?
The engine I have now is just a D15 single cam. I'm thinking about swapping instead of doing a lot of rebuild work. I'm new to the world of honda. I know there's a RIDICULOUS amount of possibilities. Right now I'm trying to find something that doesn't require much fabrication. Is there another engine besides a 1.5 that will drop in? I'm ok with buying different axles or shift linkages. A lot of other things need to be replaced as it is so why not swap out as much as I can at 1 go?
Thanks for the time and any advice you may have.
GreaseMunky is offline
Old 08-11-2011, 11:07 PM
mikejones002100's Avatar
mikejones002100 has disabled reputation
Default Re: Possible engine swap for 92 civic?
bro almost any engine can be swapped into a eg if you have the money and mechanic ability...they have direct bolt in kits for b,d,h,j,and k-series motors...its all on how much u want to spend...for an easy swap i suggest a b-series all thats needed is a ecu,94+integra mounts,94+integra linkages,94+integra axles,and a b-series swap of course and you have an easy swap to drop in....GL bro..
mikejones002100 is offline
Old 08-12-2011, 09:25 AM
Thanks for the input. I've been talking to a couple honda nuts at work and the general consensus is to go for a b18.
Are there any good go to websites to look at mount kits or things of the sort?
Old 08-12-2011, 09:29 AM
Classified Moderator
Fobby's Avatar
Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby
Try google onling shopping.
Fobby is offline
Old 08-12-2011, 01:12 PM
NAZI mod
BAN HAMMER's Avatar
A k series isnt a BOLT IN... you have to cut the frame retard.
BAN HAMMER is offline
Old 08-12-2011, 03:11 PM
I'm definately trying to stay away from cutting things. Specially the frame. A b18 is still looking good.
Is there a better B series to use if I wanted to eventually boost the engine?
