please help w/ CEL
Old 05-15-2008, 12:43 PM
Spitzehare's Avatar
Spitzehare is a jewel in the roughSpitzehare is a jewel in the roughSpitzehare is a jewel in the roughSpitzehare is a jewel in the rough
Default please help w/ CEL
throwing code 41, primary oxygen sensor, heater circuit. already changed the sensor. still throwing the code. any thoughts?
Spitzehare is offline
Old 05-15-2008, 04:31 PM
TurboPipingSystems
thermal's Avatar
Default Re: please help w/ CEL
What year, make, model Honda?
thermal is offline
Old 05-15-2008, 04:47 PM
If its not the sensor, its usually the wiring. If its not the wiring, its usually the ECU.
Old 05-15-2008, 06:05 PM
civichatch1's Avatar
civichatch1 has disabled reputation
did you reset the ecu?
civichatch1 is offline
Old 05-19-2008, 08:27 PM
Spitzehare's Avatar
88 honda crx si with 95 usdm del sol b16a3.
wiring by hasport, also locash racing conversion harness (the one hasport reccomended).
yes i reset the ecu, many many times. it shows the code with the p30 that came with the swap, as well as with a p28 from a del sol si sohc.
ironically, i also have a 94 civic ex auto daily driver that just turned the exact same code on, and i really dont wanna spend $200+ on a sensor if something else is wrong with this one.
the one in the 88crx will soon be swapped into a 93 del sol si, and im hoping the new wires will leave me with just a knock sensor code, but i want to prepare myself for what problem may still be there if the wiring doesnt end up being the problem.
nummnuttz99
05-21-2008 11:45 AM
757 BMW 525i
06-19-2007 06:46 PM
oduhockey9
05-28-2007 06:21 PM
audiophile24
06-18-2005 09:52 PM
totaled@100+
07-22-2004 01:24 PM
Quick Reply: please help w/ CEL
