piston and rod help
Old 06-17-2010, 08:27 PM
badasstoy2's Avatar
badasstoy2 has disabled reputation
Default piston and rod help
had my new b16 pistons put on my ls rods but they seem a little tighter not as much play on rods like before will this hurt anything if so what could it hurt
badasstoy2 is offline
Old 06-17-2010, 09:35 PM
Default Re: piston and rod help
So you have new pistons and new wristpins on old rods? I'm guessing the difference is that the wristpins are new and aren't worn at all, and possibly a different tolerance grade than the old ones. Plus, if they don't have much lubricant on them yet.....
Are they tight enough that they don't move freely and are sticking...?
Old 06-17-2010, 10:25 PM
ig oggggg
yanko 15's Avatar
Fabrik8 clearify this if need be
would the clearances for the rods and wrist pins be different between the LS motor and the b16?
i just remember learning something along those lines in shop class ha
yanko 15 is offline
Old 06-18-2010, 07:13 AM
I seem to remember something about the LS rods needing to be resized or something like that. I can't remember any of that stuff anymore.
Old 06-18-2010, 09:43 AM
badasstoy2's Avatar
yea they sticky not lose like the ones that came off they don't flop side to side easy
Old 06-19-2010, 04:40 AM
NAZI mod
BAN HAMMER's Avatar
Take your pistons and rods to a machine ship and have them
measure the wrist pin clearance. They need to be exactly the same
BAN HAMMER is offline
Old 06-23-2010, 07:34 AM
5literbeater's Avatar
5literbeater has disabled reputation
buy yourself a dial bore gauge and a quality micrometer. Measure con rod journal inside diameter and wrist pin outside diameter and subtract. Look up specs for rod to wristpin clearance and see where you are @.
5literbeater is offline
Old 06-23-2010, 08:13 AM
brandon.beene's Avatar
brandon.beene can only hope to improve
b16 pistons fit right on, I just did it to a ls/vtec i just built so i know 100% they will. What you are thinking about fabrik8 is having to shave the fat end of the LS rod that way the other b-series pistons will fit (GSR,ITR,CTR)
brandon.beene is offline
Old 06-23-2010, 08:17 AM
http://www.tamparacing.com/forums/ho...8b1-motor.html
http://www.ff-squad.com/tech/temp/pistons.htm
2kSi
05-14-2009 08:58 AM
2kSi
10-07-2008 05:16 PM
EvaUnit01
08-29-2004 04:40 AM
Quick Reply: piston and rod help
