PCV help please
Old 02-26-2014, 12:36 PM
spruill242's Avatar
spruill242 has disabled reputation
Default Re: PCV help please
Time or money. One of those must be spent to achieve most things.
The OP will figure out if it needs to be done. Depending on if they want to spend the time or money.
spruill242 is offline
Old 03-05-2014, 10:38 PM
Eat A Dick
Riff Raff's Avatar
Endyn breather tank
Riff Raff is offline
Old 03-06-2014, 05:03 AM
Is that made from a Sigg bottle?
Old 03-06-2014, 12:59 PM
2doors plus 2.
Yep4doors's Avatar
Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors
Originally Posted by spruill242
Wow very welcoming responses. In the time it took to type those posts an actual answer could have been given.
Route a hose to a catch can. Don't over think it. I've used PVC pipe with caps on both ends, packed with steel wool and drilled some holes for a couple brass nipples. Drilled a hole in the bottom I could unplug to drain it. Painted it black. Done.
I didn't feel like researching a proper response for the OP mainly because the OP could do the same search I could and find their answer.
Also that sounds really cheap and shitty looking, you own a Honda right?
Yep4doors is offline
Old 03-26-2014, 12:09 PM
spruill242's Avatar
Nope no honda. Just don't find the need to spend hundreds on essentially an oily air receptacle. Don't need it to win show awards. Need it to work. Would rather spend the money on track time.
You've never been on track right?
Old 03-27-2014, 06:59 AM
Tonight... You!
07Spec's Avatar
07Spec 07Spec 07Spec 07Spec 07Spec 07Spec 07Spec 07Spec 07Spec 07Spec 07Spec
Basically what dudebro is trying to say here:
and it's a cute effort
07Spec is offline
Old 03-27-2014, 06:51 PM
2doors plus 2.
Yep4doors's Avatar
I have been on a track.
I also know you get what you pay for.
/thread
Old 03-27-2014, 08:01 PM
You pay for a piece of plastic pipe with a pretty low service temperature, that's what you pay for. Did you at least step up to the baller CPVC plumbing pipe that can take slightly higher temperature instead of regular PVC plumbing pipe?
At least you didn't make the roll cage out of it.
Last edited by Fabrik8; 03-28-2014 at 06:16 AM. Reason: Ugh, sentences are missing words..
JRSCdSi
03-05-2003 04:50 PM
ritz
02-20-2003 08:42 AM
Pimp96Accord
02-18-2003 07:25 AM
Quick Reply: PCV help please
