PCV help please
Old 02-20-2014, 08:42 PM
MollysEk's Avatar
MollysEk has disabled reputation
Unhappy PCV help please
Hello guys! I've been searching forever and was wondering if I could block the PCV hole on the back of an ls block and run both hose on catch can just to the valve cover? I know there are many ways to do it but just want to make sure this way would be okay and why? Thanks Guys
MollysEk is offline
Old 02-21-2014, 03:05 AM
2doors plus 2.
Yep4doors's Avatar
Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors Yep4doors
Default Re: PCV help please
1. Wrong section
2. Why would you need this application on an LS (assuming Honda motor) by your username.
3. If you're doing it to cheap out or your going to be cheap with it, you should probably go ahead and retract your question before you feel like a dumbass.
Yep4doors is offline
Old 02-21-2014, 07:30 PM
ej1995's Avatar
ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995
Can you? Yes.
Should you? Probably not...
Why? Because if you are asking questions about it, then you probably dont understand the entire purpose of a PCV system anyway.
...oh, and IIRC, there was almost identically worded post in Tech Talk a while back.
Must not have searched very hard.
ej1995 is offline
Old 02-22-2014, 09:34 AM
Dickbutt #peentip
Kris.Is.Foamin's Avatar
Uh, not a wise idea.
Kris.Is.Foamin is offline
Old 02-23-2014, 08:01 AM
Super Secret Agent
Archer's Avatar
The big question I have is why you would want to do that?
Archer is offline
Old 02-23-2014, 10:22 AM
WEEEEEEEEEEE
TATTRAT's Avatar
Silly girl.
TATTRAT is offline
Old 02-23-2014, 12:06 PM
Dillweed's Avatar
Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed Dillweed
Seals are gonna blow out from the excessive pressure. Great way to ruin an engine.
Dillweed is offline
Old 02-26-2014, 05:42 AM
spruill242's Avatar
spruill242 has disabled reputation
Wow very welcoming responses. In the time it took to type those posts an actual answer could have been given.
Route a hose to a catch can. Don't over think it. I've used PVC pipe with caps on both ends, packed with steel wool and drilled some holes for a couple brass nipples. Drilled a hole in the bottom I could unplug to drain it. Painted it black. Done.
spruill242 is offline
Old 02-26-2014, 06:34 AM
jaqattack02's Avatar
jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02
You definitely haven't been here long if you think those are "unwelcoming" responses. They were all quite nice compared to how most of these kinds of threads go.
jaqattack02 is offline
Old 02-26-2014, 08:02 AM
NBHNC
Lay Zee H's Avatar
That's a lot of work for something that doesn't need to be done in the first place.
Lay Zee H is offline
Quick Reply: PCV help please
