ok heat gets hot when car sits and idles
but when u drive it goes cool and the heat gauge falls to nothing i ahve replace the water pump and 3 months ago i replaced the tstat its full of antifreeze so can anyone help
Needs a fast car now
Re: ok heat gets hot when car sits and idles
Did you replace and flush the antifreeze yourself? Maybe you have an air pocket in the system, did you try bleeding it yet?
temp sensor? if its warm its warm... not going to cool down just because your moving the car
Either way, its located on the back of the water neck.
to bleed the system just turn the heat all the way up, open the filler cap (unless you have a bleeder crew somewhere) and fill it up, let it run at idle and every time it burps and drops the level top it off . depending on what your capacity is it could take anywhere from 10 minutes to and hour+. my BMW holds 4 gallons of coolant so it took forever.
I GOT A 93 CIVIC JDM D15 VTEC
Cool story, bro.
Edit: You seem new. Or at least have no idea how to help us help you. Look this shit up on google or figure it out. You havent even done the simple stuff to begin diagnosing the problem. Get back to us when you do.
