oil problem
Old 07-02-2006, 07:10 AM
<3 2JZ
LSVTECEG757's Avatar
LSVTECEG757 has disabled reputation
Default oil problem
I have a 93 cx stock. it burns oil a lot, i say 3 qts. every 4-5 fill ups. Ok so last night was my day that i filled up and put oil into my car. I put three quarts in and start up and drive off. Then after about 5 mins of driving my oil light comes on. Then i checked the engine, no oil dripping or anything. I check the dipstick it says i am full of oil. BUT when i turn the car off and turn it back on the light doesn't cut on for like another 5 mins. So im like WTF. I think it might be the oil sending unit, or the pump might be bad. Tips? thanks!
LSVTECEG757 is offline
Old 07-02-2006, 06:09 PM
I am SLOW SON !!
Slepping_H22_DC's Avatar
Slepping_H22_DC has disabled reputation
Default Re: oil problem
Well if tis full and the light comes on is a pressure issue i think Hondas are under 9psi will cut the light on. When idling is when the least amount of oil pressure is present. Umm check your oil pan to see if its smashed first hopefully thats it. Oil pickup unit are really easy to crimp by bottoming out. then probably oil sending unit or pump. ect ect
Slepping_H22_DC is offline
Old 07-06-2006, 11:51 PM
lsvtecSCbeast's Avatar
lsvtecSCbeast has disabled reputation
Yep he is right but the motor doesent knock does it?if it does u might have a spun bearing!
lsvtecSCbeast is offline
Old 07-07-2006, 10:00 AM
I'm still slow.....
ZeroMR's Avatar
ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR
If the car isn't smoking at all or you aren't leaking any oil could be that sensor. Hook up a oil pressure gauge and see where it's at, if the pressure is right then you know what the problem is.
ZeroMR is offline
Old 07-09-2006, 08:43 AM
Ross's Avatar
Ross is an unknown quantity at this point
If you are loosing that much oil and there are no external leaks, then it is time for another engine.
Ross is offline
Old 07-10-2006, 08:37 AM
timi9's Avatar
timi9 has disabled reputation
Looks like it...
timi9 is offline
WhiteEg6
07-13-2008 05:39 PM
Liquidgsr
02-29-2008 06:51 AM
sick89six
04-04-2007 06:06 PM
John4teee
09-29-2005 05:03 PM
VT Prix GT 2006
05-28-2004 08:02 PM
Quick Reply: oil problem
