oil pan gasket
Old 02-01-2010, 07:26 PM
jdmwojo's Avatar
jdmwojo has disabled reputation
Default oil pan gasket
Can anyone tell me how to replace the oil pan gasket on my d16y8??
it dont look like i can just take the oil pan off
jdmwojo is offline
Old 02-01-2010, 07:32 PM
SAY IT WITCHA CHEST!
The Nisbro's Avatar
Default Re: oil pan gasket
uhh...ive always used RTV or great stuff gasket maker. i dont think ive ever actually seen a gasket meant for the oil pan.
what do you mean you cant "just take the oil pan off"?
The Nisbro is offline
Old 02-01-2010, 07:38 PM
jdmwojo's Avatar
like it seems like imma have to remove the exhaust
jdmwojo is offline
Old 02-01-2010, 07:39 PM
EMF S2K
jeremy's Avatar
jeremy jeremy jeremy jeremy jeremy jeremy jeremy jeremy jeremy jeremy jeremy
you do
jeremy is offline
jdmwojo's Avatar
i already have the gasket
jdmwojo is offline
Old 02-01-2010, 07:40 PM
jdmwojo's Avatar
can you tell me the procedure and what all i need to remove??
Is the a certain pressure im supposed to tighten the oil pan back up??
jdmwojo is offline
Old 02-01-2010, 07:41 PM
The Nisbro's Avatar
uhhh...why? ive never had a problem removing a d-series oil pan.
its pretty simple..you remove 10-15 oil pan bolts(i dunno exactly how many there are), hit the pan a couple times with a rubber mallet and the pan should separate from the block. clean the edges of the pan, apply RTV or other gasket maker and reinstall the pan. it's pretty straight forward.
make sure you drain your oil first
hand tight is what ive always done. but be very careful...oil pan bolts are small and weak...i broke 3 in a row on a Spec V lol.
Old 02-01-2010, 07:43 PM
jdmwojo's Avatar
was your d series a y8???
jdmwojo is offline
Old 02-01-2010, 07:47 PM
The Nisbro's Avatar
lolol ive never had a d-series, nor have i ever owned a honda.
last d-series oil pan i messed with was on a JDM D15B. the motor wasnt in the car at the time, so i honestly dont know if you have to drop the exhaust or not. if you have an aftermarket header then it should be fairly easy to drop.
edit- i take that back, i have done an oil pan on a d16y8..it was turbo tho, so the exhaust was routed differently. even then, i dont remember if we had to drop the exhaust or not.
Old 02-01-2010, 07:49 PM
jdmwojo's Avatar
i dont lol
i just dont wanna mess nothing up and i cant find anything on the web on how to do it in a y8
jdmwojo is offline
Quick Reply: oil pan gasket
