Oil Capacity + VTEC = ?
Old 03-14-2005, 04:01 PM
88CRXHFBSTNG's Avatar
88CRXHFBSTNG has disabled reputation
Default Oil Capacity + VTEC = ?
I was thinking about going with a larger capacity Oil pan, mainly beacause it has the fittings for turbo oil inlet hoses. I was wondering if anybody knows How a larger capacity affects VTEC? Better? Worse? or No affect at All?
thanks
88CRXHFBSTNG is offline
Old 03-14-2005, 04:10 PM
hostgator.com
flow fx's Avatar
flow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these parts
Default Re: Oil Capacity + VTEC = ?
you add extra oil with larger capacity oil pans, so I don't see how it'd be any different, only better.
flow fx is offline
Old 03-14-2005, 05:01 PM
Pan volume and oil pressure for vtec are not related, a bigger pan will have no effect at all. VTEC is either on or off, so as long you have enough pressure when you engage, you're fine.
Tim-Tim
11-27-2007 07:30 PM
9civic5
10-23-2005 12:06 PM
Goodcarbuddy
05-04-2005 11:36 PM
Quick Reply: Oil Capacity + VTEC = ?
