Odd Noise / Misfire below 2,000rpm
Old 04-14-2015, 09:49 AM
nortaP
Reloaded's Avatar
Default Odd Noise / Misfire below 2,000rpm
The car is a 2000 Ford Contour with a 2.5 liter V6 that I picked up this past winter to take to work.
It makes this noise that sounds like a "wobble" but I'm pretty sure it's a misfire.
There's no check engine light, and it will do it in neutral, reverse, or forward.
It generally happens when lifting off the throttle will start shaking and misfiring. This only happens under 2000 rpm and everything goes back to normal with a blip of throttle
For example if on highway and I lift, rpms go below 2000 and misfire. Quick blip and rpms will drop to idle like normal.
Seems worse at low speeds in a parking lot or just after the car has started up. No other issues with sluggish acceleration or poor fuel economy.
Reloaded is offline
Old 04-14-2015, 12:52 PM
A.K.A Jebus
Scotty_Nooo's Avatar
Default Re: Odd Noise / Misfire below 2,000rpm
Sounds like my roommates car when a coilpack goes to shit. I'd check to make sure all the plugs are firing (coilpacks or dizzy, can't recall what those use), look at the plugs to see whats running rich / lean / normal and take it from there.
Scotty_Nooo is offline
GSRswapEk
01-22-2011 07:55 AM
JamesPrelude
04-07-2009 07:37 AM
BadBeck
10-09-2003 10:10 PM
Rockybling
02-04-2003 03:26 PM
Quick Reply: Odd Noise / Misfire below 2,000rpm
