ODB0 B16a Problems Help please
FredVegas
I am having an issue with a recently swapped 88 si with a jdm b16a car runs great but will not go into vtec. It feels like the motor is being choked up, (not to be confused with misfiring) around 5-6k but will rev fine in neutral but in gear it chokes. It seems as if the when going past 5k the motor starts to loose power, no bucking, misfiring just simply as if you are about to hit redline or floating if you will. Possibly fuel or ignition issue?????
Re: ODB0 B16a Problems Help please
this was the motor that was in my daily crx. I have never had this problem unless it was cold,It kind of sounds like limp mode but that usually hits earlier then 5k.does it rev limit and hesitate?or does it hit 5k and slowly wind down?and please check the ecu and post if there are any codes.
http://www.b20vtec.com/forums/genera...pr3-codes.html .there is a post with the error codes. Let me know if you need help learning how to tell what code it is.
