obd-0 to obd-1 need help
Old 02-13-2007, 07:28 AM
killergsr's Avatar
killergsr is an unknown quantity at this point
Default obd-0 to obd-1 need help
ok i just got the motor out of my eg but i dont know what to do.i have a
b18a1 from a 90 integra i got a obd 1 harness and a b16 hydro tranny i dont noe wut else to used from my old integra like axles or shiflinkage or motor mounts also wut clutch should i use cuz the ls clutch dont fit the b16 i need alot of help thanx i did research on up but i dint find anything on it so please help thanx alot in advance
killergsr is offline
Old 02-13-2007, 02:07 PM
TurboPipingSystems
thermal's Avatar
Default Re: obd-0 to obd-1 need help
it would help if you tell us what car this motor is going to....
thermal is offline
Old 02-13-2007, 02:10 PM
killergsr's Avatar
93 eg hatch
Old 02-14-2007, 03:33 PM
pstevo247's Avatar
pstevo247 is an unknown quantity at this point
put it back together and trade it for some thing already swaped man like my si crx with an ls already in it
pstevo247 is offline
Old 02-15-2007, 02:29 PM
89sihatch's Avatar
89sihatch is an unknown quantity at this point
get any b series hydro tranny clutch and bseries into eg mounts and shift linkages, you may have to switch the motor mount braket on the motor by the timing belt, use a obd1 ls ecu and you can use the axles and half shaft from the integra and re pin the dizzy from the integra
89sihatch is offline
Old 02-15-2007, 02:51 PM
fraggle rock
kyle h.'s Avatar
kyle h. will become famous soon enough
b series into eg mounts don't exist. and you wont be able to use an obd0 dizzy with an obd1 computer.
kyle h. is offline
Old 02-17-2007, 09:37 AM
audiophile24's Avatar
audiophile24 has disabled reputation
i have all the mounts from a dc teg you can use i will let em go for 35.00. all you need is the k bracket the half shaft and make sure you have ex hubs up front, you will also need an obd1 dizzy and a p75 i think it is or a p14? not sure had a p75 in mine. you also need the shift linkage from a dc teg just sold mine i think that is all you would need besides the wiring harness off of your old motor you may need to get obd1 injectors.
audiophile24 is offline
Old 02-17-2007, 07:13 PM
killergsr's Avatar
thanx alot guys
Kris.Is.Foamin
Want to Buy / Trade ARCHIVE
12-27-2007 05:23 PM
Quick Reply: obd-0 to obd-1 need help
