Not getting oil to head
Old 03-04-2009, 04:37 PM
TPH-DC2's Avatar
TPH-DC2 has disabled reputation
Default Not getting oil to head
Alright so it begins like this I have a gsr block that we took the pistons out to install type r pistons....we then put the gsr head on and started the vehicle...but for some reason it's not getting oil to the head.... I took the oil cap off and no oil....it's an OBD1 and I just can not think of what it can possible be...please help
TPH-DC2 is offline
Old 03-04-2009, 04:51 PM
Default Re: Not getting oil to head
I can't remember what the GSR head pattern looks like, but is it possible you put the head gasket back on rotated the wrong way?
Old 03-04-2009, 05:55 PM
RandomTask's Avatar
How are you sure you're not getting oil to the head? Do you have oil pressure? I'd imagine if you blocked the oil off like that, you're pressure would be pegged.
RandomTask is offline
Old 03-04-2009, 07:48 PM
Bearded.
DORKO's Avatar
Listen to him.
smartest motherfucker on the board.
hands down.
Pull the head off, get a new gasket, and make SURE its on the right way before you torque it down.
DORKO is offline
Old 03-04-2009, 10:26 PM
TPH-DC2's Avatar
Well I guess the best thing for me to do now is take the head off..and check the head gasket... I am not getting oil pressure I believe...I am wondering could it possibly be the oil pump? Or maybe oil pick up gasket
TPH-DC2 is offline
Old 03-04-2009, 10:30 PM
Yeah, it could be one of those things. Anything that you moved, removed, replaced, etc., you should check to see that it's functional and reinstalled properly. It's probably something fairly simple that you didn't catch when you were putting something back together.
Old 03-05-2009, 06:43 AM
Keeping It Real !!
ravenracer's Avatar
ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer
I think you can install the head gasket only one way because it has different bolt patterns all around. He could have forcedly installed it the wrong way.
ravenracer is offline
geoff240sx
08-30-2008 09:11 PM
PoS hYbRiD
12-03-2007 09:28 PM
Quick Reply: Not getting oil to head
