non - consistant idle - need help
Old 05-15-2008, 09:07 PM
spoonej1's Avatar
spoonej1 has disabled reputation
Default non - consistant idle - need help
My vehicle in the morning and when it first starts up idle's fine, after you warm it up or after initial start the idle jumps from about 800-1500 rpm's constantly unless you give it a little gas and stay there with the trottle, this happens when it's just sitting in the parking lot, or when you take it out of gear and just coasting to a stop. What do you think it is? Car is a 93 honda Civic Vtec mini me with a y8 intake mani. Thanks
spoonej1 is offline
Old 05-15-2008, 09:10 PM
Ramey Built
JB@RameyBuilt's Avatar
JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt
Default Re: non - consistant idle - need help
check the IACV... make sure it's not clogged up or anything.
JB@RameyBuilt is offline
Old 05-16-2008, 08:58 AM
spoonej1's Avatar
Is the IACV under the throttle body or attached to the rear of the manifold? I can't remember and always get those two confused. Thanks for the help
spoonej1 is offline
Old 05-16-2008, 09:46 AM
nce
nce's Avatar
nce has disabled reputation
The fast idle thermal valve is the one under the tb ,Iacv is on the back of the mani. Sounds like its probaly the fitv . If you look inside the tb there is 2 ports on the left side . one goes to the iac the other to the fitv . check and make sure that when the motor is warm that there is no vaccum on the bottom one, if there is its the fitv. block it with your finger. if it idles right then thats your problem. most times they just need cleaned
nce is offline
Old 05-16-2008, 12:48 PM
Ramey Built
yeah that was gonna be my other advice... hope you get it fixed
Old 05-20-2008, 06:17 PM
not a noob
JAvenger's Avatar
JAvenger has disabled reputation
check for vacuum leaks.
JAvenger is offline
DJ Lip
09-23-2008 05:27 PM
hondapwr92
06-24-2008 07:54 PM
rotaryking
08-17-2006 04:39 PM
200+hp240sx
07-01-2006 11:30 AM
mksblckracer
02-02-2005 11:49 AM
Quick Reply: non - consistant idle - need help
