No spark in my Power Ram
Old 02-16-2010, 04:18 PM
cobia fisher's Avatar
cobia fisher has disabled reputation
Default No spark in my Power Ram
My 86' dodge w150 (power ram) w/ 360 4 barrell wont start. I Have pulled the spark plug and set it on the block and tried starting, no spark. Next step i took the main plug going from the ignition coil to the top of the distributor i put that to the block and tried cranking no spark untill i stopped cranking and a quick spark happened as i was turning the key away from the cranking position.
All plugs and wires are in the right places and on tight
I have brand new plugs and wires(plugs are gapped to spec), ignition switch, ignition coil, distributor cap, distributor cap rotor button.
Next step tomorrow would be the ignition module.
Any other ideas would be great, i have done what i know and hasnt worked for me
cobia fisher is offline
Old 02-16-2010, 04:25 PM
baller/dickbutt#69
nftuatn's Avatar
Default Re: No spark in my Power Ram
ignition module
or does it have points in it???
if so the points are not making/breaking
nftuatn is offline
Old 02-16-2010, 04:30 PM
There is one on the driver side fender that has three wires going in/out of it.
Old 02-16-2010, 04:39 PM
DisturbedFocus's Avatar
DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus DisturbedFocus
cobia are faggots.
goodluck
DisturbedFocus is offline
Old 02-16-2010, 04:43 PM
If i wanted to discuss the sexual prefrence of fish i would go to a fishing website. Thanks
Old 02-16-2010, 04:44 PM
fuck you, I hope your truck explodes.
Old 02-16-2010, 04:45 PM
typesb4thinking
nosediv3's Avatar
nosediv3 nosediv3 nosediv3 nosediv3 nosediv3 nosediv3 nosediv3 nosediv3 nosediv3 nosediv3 nosediv3
dude didnt i just watch you and sam change the ignition module?
nosediv3 is offline
baller/dickbutt#69
nftuatn's Avatar
op may not last long...
nftuatn is offline
Old 02-16-2010, 04:46 PM
typesb4thinking
nosediv3's Avatar
its just roidrage, dont let it bother you dude
nosediv3 is offline
Old 02-16-2010, 04:52 PM
Everything in the cap is dry and looks fine. like i said its new so there isnt any wear yet. i put the cap on in the right place. In the manuel i have it states that i have a ignition mod and i located it right before dark.
Quick Reply: No spark in my Power Ram
