no to little boost?? help
i have a 90 eclipse gsx i the turbo has been replace (the old one was locked up when i got the car) i have a manual boost controller and no matter what i do there is no /little boost ???? help i am ripping my hair out with this
Re: no to little boost?? help
Check the wastegate arm, make sure it is attached to the accuator arm on the turbo. If its disconnected, you wont see any boost at all, maybe 1psi max. Have you done a boost leak test yet?
basically you hook a regulated boost source up to the inlet of your turbo and see if there are any leaks at any of the couplers on your charge pipes, intake manifold, etc..
My guess is that the wastegate actuator took a shit. The diaphrams on them fail after a while and give the same symptoms that you are describing.
what is the best way to do a boost leak test i understand that you want to put it under pressure but how the hole is 2 inchs?????????
try this link for boost leak. this helped me out alot.
http://www.srtforums.com/forums/showthread.php?t=67962
make sure you check post #3, it tells you how to build your own leak tester.
❒Good ❒ Better ✔Best
Originally Posted by dsmfan
the cart. out of a volvo a tdo5h?? i gotta look at the old houseing
