-   -   nitrous (https://www.vadriven.com/forums/tech-talk-9/nitrous-91814/)
gen4H22A Apr 25, 2005 01:22 PM
nitrous
I got a dry kit today for my h22.....im only running a 55 shot right now but i plan to make it run a 75 shot safely......I plan on getting colder plugs a vafc and a fuel pump.......
from eveyrones experiences would it be overkill to get larger injectors, bigger fuel rail and fpr? or would it be a smart upgrade
thanks in advance
gear Apr 25, 2005 01:34 PM
Re: nitrous
youre getting to your limit on stock rods etc. I wouldnt go any higher then the 75 with all of the upgrades you plan on doing...but thats just me. A slightly slower motor is better then a non running 'fast' one.
gen4H22A Apr 25, 2005 05:27 PM
Re: nitrous
yea 75 is about the most my motor can take unless i did direct port...
4nmusle Apr 25, 2005 06:39 PM
Re: nitrous
I have put nitrous on just about everything from my exp...Colder plugs and a timing light is your best friend....NO NO NO NO to v-afc or injectors....Fpr would help some done right....PM if you have more ? GOOD gas is a plus ...
ek9inch Apr 25, 2005 06:45 PM
Re: nitrous
listen to sean, hes the man with the spray
Voodoo ST Apr 25, 2005 07:18 PM
Re: nitrous
first of all i would change to a wet kit, they are safer and more reliable!
themacuser.org Apr 25, 2005 08:23 PM
Re: nitrous
dry kits are for poor high school kids who don't care about their engines.
but staying on topic - the more fuel you put in your engine, the less chance of the nitrous blowing your head through your hood.
fmstatic Apr 25, 2005 10:08 PM
Re: nitrous
yeah you should definitely have gotten a wet kit. I like NX, but its really personal preference.
bigger injectors, vafc, etc = overkill
colder plugs = smart
NX makes an fpr safety switch, its for people who want to be extra safe but whether or not you should bother with it is really up to you. I think its unnecessary, but its still a good investment. basically if your fuel pressure drops below I think (?) 44-46 psi then the fpr safety switch will disarm your nitrous to keep you from running lean & detonating.
and if you run a wet kit, then a 75 shot will be fine. that's what I've been using on my 4 banger for almost a year now
themacuser.org Apr 25, 2005 10:29 PM
Re: nitrous
I don't know how Honda engines work, but to the rest of the automotive world, adding fuel to a dry-kitted engine is never a bad thing.
CHAHONDA Apr 26, 2005 06:48 AM
Re: nitrous
thanks in advance
a fuel pump would be a wise choice. slightly larger injectors arent bad either. a vafc would be fine as well. i hope you have a better than stock clutch as well or all of this will do no good! i was running a 75 shot on my civic for a long time! what kit/system do you have?
