nitrous
I got a dry kit today for my h22.....im only running a 55 shot right now but i plan to make it run a 75 shot safely......I plan on getting colder plugs a vafc and a fuel pump.......
from eveyrones experiences would it be overkill to get larger injectors, bigger fuel rail and fpr? or would it be a smart upgrade
thanks in advance
thanks in advance
youre getting to your limit on stock rods etc. I wouldnt go any higher then the 75 with all of the upgrades you plan on doing...but thats just me. A slightly slower motor is better then a non running 'fast' one.
I have put nitrous on just about everything from my exp...Colder plugs and a timing light is your best friend....NO NO NO NO to v-afc or injectors....Fpr would help some done right....PM if you have more ? GOOD gas is a plus ...
Originally Posted by V8 Hunter
first of all i would change to a wet kit, they are safer and more reliable!
but staying on topic - the more fuel you put in your engine, the less chance of the nitrous blowing your head through your hood.
bigger injectors, vafc, etc = overkill
colder plugs = smart
NX makes an fpr safety switch, its for people who want to be extra safe but whether or not you should bother with it is really up to you. I think its unnecessary, but its still a good investment. basically if your fuel pressure drops below I think (?) 44-46 psi then the fpr safety switch will disarm your nitrous to keep you from running lean & detonating.
and if you run a wet kit, then a 75 shot will be fine. that's what I've been using on my 4 banger for almost a year now
thanks in advance
thanks in advance
