need turbo help
need turbo help
Hey I just got my first turbo set up here is the pic.
But I just wanted to know where the long braided line goes that connects to the left of the turbo on the top of the mani, and it has a tube on the bottom of the turbo I think is the drain tube but just need to make sure, and do I need to buy more lines for the oil return lines, and what goes to the top of the BOV. This is my first kit and I am really confused about the oil lines and where all the lines go could someone help me thanks.
Re: need turbo help
runs from the top of the turbo to where u take out the oil guage off the back of the block. or if u buy a sandwich plate to go behind the oil filter.Did u get a already tapped oil pan for the return line?
Re: need turbo help
You really need to do some reading...... www.homemadeturbo.com is your place for knowledge.
Re: need turbo help
braap braap
Re: need turbo help
If you were local I'd show you in person.
Since you aren't listen to Flipside
BTW, please get tuned.
And nice car.
Welcome to the world of a Boosted Honda
And nice car.
Team Rad Racing
Re: need turbo help
First thing you need to do is throw away that piece of shit FMU, its the blue round thing. Next the braided line goes to the oil sending unit which is underneath your intake manifold by your oilfilter. Like already said you will need an adapter so you can a T off it. The drain tube on the bottom of the turbo is the oil return line and you will need to have your oil pan taped for it. Your blow off valve hooks in with your vacume lines along with your wastegate, boost gauge, and boost controller if you have one.
Carolina Kracker
Re: need turbo help
Re: need turbo help
Dont use a T fitting as most of them are brass and the added weight + vibration make them extremely prone to snapping off at the threads. To the OP, get yourself a Golden Eagle Mfg. oil sandwich:
http://www.accountwizard.com/clients...tem&itemid=340
Unsure if that link will work for you or not. Don't just slap a turbo on and be done with it, there is so much more that must be done to ensure you do not blow your engine/ring lands. I concur with ridding yourself of the FMU, it's stuck out like a sore thumb to me immediately after seeing the picture. Get yourself Crome or Hondata and get it tuned. Yes, you'll hear that alot, "get it tuned" and I would only hope you heed those words of wisdom.
Re: need turbo help
Ok thanks guys I am located in manassas so if anyone is kinda close that wouldn't mind showing me or something I could give someone like 20 to help me and show me what i need and where everything will be hooked up at thanks PM me if so thanks alot for the help and i will get rid of the fmu lol
