Need some help from you people able to pull off a dumped car with no problems!!!
Old 12-05-2009, 01:04 PM
MICK LVN's Avatar
MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN
Default Need some help from you people able to pull off a dumped car with no problems!!!
Well I just picked my integra up from Stock or Modified Bodyworks and put my wheels on (16x7 +38 Work Miesters). I adjusted the coilovers (Fortunes) and the car is low but def not near as low as I have seen guys pull off. I am running a 205/45/16 and with a decent amount of turning it rubs like crazy! It doesnt rub on the fender but sounds like its on the inside. My first thoughts were to remove the fender, see whats rubbing, and cut away! BUT I figured if there were any other suggestions or anyone that had the same thing happen before, I listening. Thanks in advance!
MICK LVN is offline
Old 12-05-2009, 01:07 PM
urmomsawhore
KillaBeezyB's Avatar
KillaBeezyB KillaBeezyB KillaBeezyB KillaBeezyB KillaBeezyB KillaBeezyB KillaBeezyB KillaBeezyB KillaBeezyB KillaBeezyB KillaBeezyB
Default Re: Need some help from you people able to pull off a dumped car with no problems!!!
id try to roll the fenders with a bat
KillaBeezyB is offline
Old 12-05-2009, 01:11 PM
MICK LVN's Avatar
i need someone with experience and you obviously have none. that fenders are rolled! not to mention id never go at any part of my car with a bad. If you read my whole post, ITS NOT RUBBING THE FENDER! its rubbing on the inside somewhere. kthx
MICK LVN is offline
Old 12-05-2009, 01:14 PM
Blowin' smoke.
tdi520's Avatar
tdi520 is a jewel in the roughtdi520 is a jewel in the roughtdi520 is a jewel in the rough
Easiest thing to do is either jack up the car or take the wheel of. Have a look where it's rubbing and go from there.
Taking the plastic lining out of the fender will help some, but you also need to be worried about the wiring harness that usually runs inside the fender well (people cut through it with tires all time time).
tdi520 is offline
Old 12-05-2009, 01:15 PM
FUCKIN MAGNETS
shawn22's Avatar
No such thing as pulling off a dumped car with no problems unless you dont drive it.
You just deal with the problems by ignoring them until they clearance themselves.
shawn22 is offline
Old 12-05-2009, 01:18 PM
MICK LVN's Avatar
well i dont have any plastic lining. sounds like maybe one of the "pinched" seams in there
There is such thing as dumping a car without it rubbing like this. Dont know if i just need to cut out whats rubbing, maybe run a more narrow tire, or shorter series sidewall, or a spacer or what. just looking for someone that has gone through this before
MICK LVN is offline
Old 12-05-2009, 01:19 PM
Dickbutt #peentip
Kris.Is.Foamin's Avatar
Break out the BFH. I have 16x7.5+35 225/45/16 and it used to rub inside the wheel well. #1, the deathseam- that will KILL your tires, beat the flat (Take out fender liners lolol). Look for shiney metal for rubbage, beat with hammer ????????????????? profit;
Kris.Is.Foamin is offline
Old 12-05-2009, 01:24 PM
Mindless's Avatar
Mindless is an unknown quantity at this point
Probably the fender lining. I have rubbed one gash in mine so far and it still makes noise sometimes when turning. I would say I'm low but not dumped:
Shitty cell pic.
Mindless is offline
Old 12-05-2009, 01:25 PM
MICK LVN's Avatar
sounds like thats what i will have to do. thank you
MICK LVN is offline
Old 12-05-2009, 01:26 PM
Danny@respecgarage
RE-SPECGARAGE's Avatar
picks of the said dumped car
RE-SPECGARAGE is offline
