Need some help after replacing clutch master cylinder
Hello honda heads I am in need of some tips and tricks. Recently I replaced my clutch master cylinder sounds simple enough right? Well long story short messed up a seized fitting so bought a pre flared line from advanced and replaced it and made sure I had no leaks . While bleeding the clutch I noticed that no fluid was going down from the reservoir . Tried everything to see if any fluid would get pushed thru the CMC to the lines so it could come out the bleeder valve but nothing.what can I do? Just keep trying to bleed it and hope for the best or what? Any info would help a lot thanks for reading.
Re: Need some help after replacing clutch master cylinder
So you're saying no fluid is going to the clutch slave cylinder and no fluid is coming out of the bleed valve on the slave cylinder? Does that line you bought have a check valve or something in it?
no it does not have a check valve. there might be a block in the system somewhere because it seems that no fluid is pushed into the CMC for it to go thru the lines so it can be bled. other than that im stumped because I already have it rigged and stuff its not the best work but as long as it works im ok with it.doesent have to look shop fixed but if it works ill be ok. I mean yesterday I noticed some fluid level change so I might be in ok shape .just going to wait till I get home. will update post when I find out if im good.
