Need help.Wiring harness?? conversion??
Old 12-15-2008, 04:04 PM
got vtec?
SOHC_CriX's Avatar
SOHC_CriX has a little shameless behaviour in the past
Exclamation Need help.Wiring harness?? conversion??
so i was doing my swap today for the new d16 vtec in my crx, i was puttin the wiring harness together and i notice that the old wiring harness didnt have the plug for the d16 distriubter. the wiring harness was connected to a d15b2 before the swap, what do i need to do or buy so i can get the right plug for the distibuter???
SOHC_CriX is offline
Old 12-15-2008, 04:11 PM
kwint's Avatar
kwint has disabled reputation
Default Re: Need help.Wiring harness?? conversion??
Did you convert to mpfi? Are you using a pre made conversion harness?
kwint is offline
Old 12-16-2008, 02:41 AM
got vtec?
SOHC_CriX's Avatar
yes and yes
Old 12-16-2008, 06:16 AM
got vtec?
SOHC_CriX's Avatar
anybody else know wut i should do???
Old 12-16-2008, 08:08 AM
MajorsEF's Avatar
MajorsEF will become famous soon enough
your welcome in advanced....u can either repin or cut and splice. find a obd1 eg harness, cut the 2 dizzy plugs off. if u plan to cut and splice leave about 4 inches. then cut your stock one. i spliced mine together and never had a problem. all the wire colors are the same, they all match up. there are 2 white wires, leave these for last. you have to pull back the loom and see which one sits outside the bunch, this will be considered the bigger white wire. ok heres a diagram i made. good luck.
OBD0 OBD1
orange) (orange
white) (white
orange/blue) (orange/blue
white/blue) (white/blue
blue/green) (blue/green
blue/yellow) (blue/yellow
large white) (yellow/green
black/yellow) (black/yellow
blue) (blue
MajorsEF is offline
vitale999
09-04-2006 07:12 PM
JayDeeM
02-27-2003 04:29 PM
Quick Reply: Need help.Wiring harness?? conversion??
