need help,what does a spun bearing sound like?
Old 06-20-2009, 12:49 PM
b182boost's Avatar
b182boost has disabled reputation
Default need help,what does a spun bearing sound like?
my car started running like sh*t and i can hear a lot a vibration that sounds like its coming from the bottom end(vibrating the dash n what not like crazy)any one describe what a bad bearing sounds like????
b182boost is offline
Old 06-20-2009, 01:05 PM
Double Agent HT
ILLEGAL's Avatar
Default Re: need help,what does a spun bearing sound like?
when I spun a bearing, the motor stopped running.
I say check the oil, get on the highway and do 100+ in third gear for 10 min straight, should clear out whatever build up you have.....
just kidding
ILLEGAL is offline
Old 06-20-2009, 01:22 PM
DeFunk's Avatar
DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk
It's also called rod knock because, it sounds like a knocking noise. Does the knocking get faster as you rev the engine (at a stand still/neutral)? Is the volume louder or quieter while driving under load (driving on the road vice neutral)? If you believe you have a crushed bearing, you'll have debris in your oil, so drain your oil into a container that you'll have open access to. Wade around this with a mechanics magnet (magnet on a telescoping antenna looking type deal) or some other worthwhile magnet (those bendable type that stick on the fridge doesn't qualify as worthwhile imo). Did you pick up shreds/bits of metal?
Check your engine mounts too, though the running like shit part. Hmm. Having a shot spark plug/wire and bad engine mounts would act like you describe, since you didn't mentioning a knocking/banging type of noise.
What noise is there?
DeFunk is offline
Old 06-20-2009, 01:36 PM
team703's Avatar
Maybe loose lugnuts is causing the vibration and a shorted plug wire arking makin it run like shit
team703 is offline
Old 06-20-2009, 01:38 PM
team703's Avatar
just kidding
LOL, well i would say do that if you plan on replacing the motor, might make for a good story later!!!
team703 is offline
Old 06-20-2009, 02:25 PM
b182boost's Avatar
well,its been burning alot of oil,so i knew it was going to need to rebuild it,and it was knocking too.but last night driving home it started to sound like my lug nuts were loose on one of my front tires,so i checked when i got home and they were good.about an hour later when i went to start it it was making strange sounds that i've never heard from an engine before.it was like a deep vibration, pulsating at idel.and when i drove it it sounded worse.it was vibrating the dash so much that it sounded like it would fall off if i let it run long enough.i'm going to change the oil and sift through it to see if i pick up any metal shavings tonight.
Old 06-20-2009, 09:41 PM
SOHC's Avatar
SOHC has disabled reputation
a spun bearing sounds like a ticking that matches the rpm; if you rev it up and the ticking revs up equally with the rpm, then it might be a spun bearing. its not too tough to check though...pull the oil pan off and you can get at the rod caps and see for sure.
SOHC is offline
Old 06-21-2009, 01:09 AM
Fidel runs VBPD
The_rabbit1's Avatar
The_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud of
you are not running on all cylinders... and i mean that...
The_rabbit1 is offline
Old 06-22-2009, 07:53 AM
RandomTask's Avatar
Signs of a spun bearing
Significant loss of oil pressure,
Loss of power
Inability to idle without throttle
If you had rod knock before, a spun bearing or a rod out the side of the block usually follow soon after.
RandomTask is offline
Old 06-22-2009, 08:05 AM
Digital Life
83Stang5.0's Avatar
Loss of power
I spun 2 bearings at once, and my shit still idled.
Of course I sounded like a diesel truck.
83Stang5.0 is offline
crxdudesi
02-29-2008 03:40 PM
99hatchR
12-22-2006 06:31 PM
F4Fresh
02-07-2005 12:44 PM
JAvenger
03-31-2004 12:00 PM
Quick Reply: need help,what does a spun bearing sound like?
