need help!! wastegate and bov vacuum lines plus pwm hook up
Old 12-21-2010, 03:50 PM
sweethatch1866's Avatar
sweethatch1866 has disabled reputation
Default need help!! wastegate and bov vacuum lines plus pwm hook up
if any one can direct me to a diagram or give me detailed directions it would be great. Im running a b series turbo engine with hondata s300 engine management. This is the first turbo engine i have built so i need a lil assistance with my vacuum lines. Im also going to use the pwm option with the hondata unit. Mainly what im looking for is how/where to hook up my vacuum lines. If any one has it, I also need a wiring diagram for and external resistor for my injectors and wiring for boost solenoid. Thanks
sweethatch1866 is offline
Old 12-21-2010, 04:06 PM
RIP DRAGVA-2016
NasTHatch's Avatar
Default Re: need help!! wastegate and bov vacuum lines plus pwm hook up
There are several ways to run the lines, there is no one set way to do it.
NasTHatch is offline
Old 12-21-2010, 04:49 PM
Look up resistor box wiring for the injectors. I'm assuming you're using OBD0 injectors that actually need a resistor box?
Here's some vacuum line help from Hondata's site:
http://www.hondata.com/s300boostcontrol.html
The rest of the vacuum line hookups can be found with a Google search.
Old 12-21-2010, 04:51 PM
im running rc 1000cc injectors that require a resistor.
Old 12-21-2010, 04:55 PM
I found this with Google:
http://www.beesandgoats.com/boostfaq/g2icturbo.html
Read all of it, it probably has all the info you need. Hopefully it's accurate (I'm not going to read it and find out).
Oh, I do see there is some resistor box information buried somewhere in that link.
s2kdreamer
06-20-2010 06:53 PM
barrywayne
05-02-2010 12:26 PM
shonanspeed
12-08-2008 06:07 PM
Egz
08-05-2003 01:45 PM
Quick Reply: need help!! wastegate and bov vacuum lines plus pwm hook up
