Need help W/ 99' Accord
Formerly da_clipse
Being a DSM guy i'm not really sure what engine is in it, but my aunt is down for the weekend and wants to get her state inspection done, just changed the oil..... etc. Need to know where you check transmission fluid at. The car is a 5 spd. Is there a sight glass or... what? I see no dipstick or anything. I saw some numbers on the timing belt cover saw f23, was guessing that might be it. Will post pictures in a few.
Re: Need help W/ 99' Accord
Passenger side, just about level with the axle there is a 17 mm nut. Remove and fill til fluid JUST starts to run back out. 10w 30 motor oil is what you want to put in the trans belive it or not.
Formerly da_clipse
Thanks man, i found an online manual like .5 seconds after you posted lol. Thanks a million. I always heard you colud put motor oil in for a honda's tranny fluid but never thought it was true. lol would you happen to know what engine this is?
there are two drain plugs on the side of of the casing of the trans. I've always just pulled the top plug and used a finger to feel for fluid level. If its at the right level you should feel some fluid.
Shooting 63's
F23A1 Accord Motor
Single cam w/2.3 liter displacement
Here are some more exact specs.
Bore × Stroke: 86.0 × 97.0 mm
Displacement: 2254 cc
Valve Configuration: SOHC, 16 valves, VTEC
Compression ratio: 9.3:1
Max power: 150 hp (112 kW) @ 5700 rpm
Max torque: 152 ft·lbf (205 N m) @ 4900 rpm
