-   -   Need help with type r Intake Manifold (https://www.vadriven.com/forums/tech-talk-9/need-help-type-r-intake-manifold-46160/)
druidprints Mar 18, 2004 05:50 PM
I got a B16A1 put into my CRX , but having problems with the idle(manifold fuel rail, injectors and throttle body is Type r) Any sugestions?
Bert Mar 18, 2004 08:27 PM
Re: Need help with type r Intake Manifold
use the obd0 injectors...the type R injectors are saturated and won't work...the obd0 injectors are the same flow rate as type r injectors anyways so there isn't any reason to change them...try that first.... if you changed to obd1 then you can run the type R injectors just be sure to remove injector resistor box...
